cluster to array help
I am fairly new to using clusters for this purpose.
Is there an eaiser way to do what I have shown in the clip below?
The bulit in cluster to array is not really any eaiser becuase then I have to index or use array subset to get the proper files paths or visa sessions.
=== Engineer Ambiguously ===
(3,436 Views)
you can use the cluster to array.vi
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,431 Views)
and instead of using a for loop you could use an index array
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,426 Views)
Yes but there are more than the five eliments shown in the clusters and cluster to array converts the entire cluster to an array.
Then I have to index out the single or element I need or use array subset the get the few I need.
That means I have to remember exactly what order the cluster elements are in, and I am trying to make things eaiser.
(3,424 Views)
Accepted by RTSLVU
what you have now is fine than if you have more than five element and you only want to extract a few
Message Edited by Harold Timmis on 09-28-2009 12:39 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(3,419 Views)
I guess I am doing it right for once.Smiley Happy
Thanks.
(3,388 Views)
