cluster of multi-plot xy graphs
I have a cluster of single-plot xy graphs. The data is pulled from a file, assembled in a for loop, and passed to the graph cluster using the array to cluster function.
Now I need each graph to have multiple plots. The array that built the original data clusters of x and y arrays now must make arrays of these clusters, one for each plot. So, I tried passing these arrays into a cluster before pussing out of the for loop, but I can't get the graph cluster to accept the result. I've also tried indexing out a 3-D array and getting a 2-D array of graphs to accept this data, to no avail.
Any ideas?
I've made an attempt to create snippets, but it's my first time doing so, so thank you for your patience.
_____________
Creator of the BundleMagic plugin for LabVIEW!
(6,087 Views)
Can you attach these VIs?
Matt
(6,075 Views)
Just looking at this, you can not pass a 2D array of clusters to a xy  graph control.  You need to flatten this data to 1D, so maybe have a shift register that contains the array and intialized with a null array and then keep adding to the array.
Matt
(6,071 Views)
Thanks Matt, As you can see, I've tried a number of things. The 2-D array of clusters (of x and y arrays) was one attempt to write to a 2-D array of x-y graphs... no go!
I'm thinking the way to go it to write to a cluster or array of pngs.
_____________
(6,053 Views)
The problem lies with the type definitions, they are single-plot XY graphs. You need to change them to multi-plot (array of clusters of 2 arrays).
This is what I came up with (removed all typedefs):
Note that the reference connected to the 'controls' property node refers to the "graphs" cluster inside "cluster".
What an Smiley FrustratedinterestingSmiley Frustrated way of grouping data... I would have opted for a cluster of [string and array of graphs].
What you use is a cluster of 2 elements:
   - string
   - cluster of 32 elements:
       - cluster of array of cluster of 2 arrays   Smiley Sad
(6,048 Views)
Thanks, I'll have ot study this! I inhereted this code. I would also have preferred an array of graphs, and tried that, but couldn't get it to work.
_____________
(6,035 Views)
You can not write 2-D anything to an XY plot.  In what you showed, you were writing a 2D array of clusters to the XY graph.  That being said, I think what you meant is a 1D array of clusters containing 2 arrays (an X and Y).  I think Pianne may have hit on your problem.  I saw this as a problem of trying to fit the data into the XY graph, but what you are saying is that the problem is in the cluster value (the XY graph should adapt to the input).  This is a cluster type definition issue so I now defer to Pianne ;).
(6,018 Views)
