cluster behaves like array in lv8.6.1
Please find the attachment, where I have changed the values. Please check the hotfix which the above post mentions.
-Mallya
" Appreciate and motivate those who help"
Message 11 of 13
(705 Views)
Yes, 8.6.1 has all kinds of issues with min/max.  It's actually the DIALOG which is screwed up, the actual properties work OK, but you can't adjust them correctly from the dialog.
 Look for the patch: 8.6.1f1 Patch
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 12 of 13
(696 Views)
Thanks Norbert. I have downloaded and installed. Now its working.
Mallya you might have told about the hotfix first hand.
Anyway thanks for all your time & support.
Kousy
Message 13 of 13
(666 Views)
