close executable
I need to be able to have an executable automatically close itself after it runs, all the executable will do is write to a hardware device over GPIB.  Is there a good way to close it after execution without having to close LabVIEW?  Any suggestions are welcome.
Cheers
(3,205 Views)
Use a reference to the VI, and an invoke node->Front Panel->Close...both found in the same pallete as 'Quit LabVIEW' (which is what I assume you meant when you said 'Close LabVIEW')
Which you COULD set in the VI properties to begin with...
Message Edited by TWGomez on 04-25-2008 09:47 AM
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(3,203 Views)
Hai,
Try searching this forum with the keyword - 'automatically close vi' .
You can find a couple of solutions.
Mathan
(3,199 Views)
