clone reference equal
You assume wrongly that clones are completely independent copies of the same VI. They are not! A clone maintains an independent dataspace but for everything else like code etc refers to the single master copy of the VI.
You make assumptions about the equal operator that are wrong in the current situation. You can feel sorry that it doesn't work the way you would want but the likely truth is, that if you insisted on it working like this, clones might never have been possible to implement in the current LabVIEW architecture.
Rolf Kalbermatter  My Blog
Message 11 of 13
(1,306 Views)
Arleady found way around that. Just asking why it works in that way...
Message 12 of 13
(1,290 Views)
Well technically it is the same VI, just not the same instance of it. Take two integer values, should equal give you false for the same integers because they are technically two different instances (memory locations)?
Message 13 of 13
(1,275 Views)
