client and server
currently, i am facing the problem in the server side.Whenever  i turn the button in the hot/cold water in the client side, the tank colour in the server side will not change immediately unless you change the water level again.Another problem is how could i make the power button have the high priority and before i need to open the power button before change the control like hot/cold /water level and function something...
(2,779 Views)
I don't see where you are writing the tank level at all in the server.  What am I missing?
You also don't have a way to stop your VIs.  You realy should fix that so you can clean up your TCP connections.  Also, don't just blindly clear errors.  They happen for a reason.  You should instead figure out what is causing them and fix that.
(2,738 Views)
the tank level is the water level that show the volume at server side, case structure 05, so far, my progress still not cover the pause function but will be complete later.
(2,731 Views)
