clear xy graph at call
Hi, i am brandnewSmiley Wink. At least at using labview. I am using it for a month now. I have a question.
I have a multiple stripchart with different inputs. All these inputs are just using the Y values of the input signals.
I made an xy graph where i can choose wich signal i want to see via an enumerator (case value). say signal 1-8. this all works ok.
But when i choose an signal say nr 3 or so. it does not clear out the last signal wich was on the xy graph.
While measuring, everytime when i choose a signal the xy-graph should be cleared and start fresh with the chosen signal.
How do i do this? (i tried different things like shifts-registers and so on)
Please help, thanks a lot.
(3,111 Views)
If you want a quick solution, post a simplified version of your vi, using short Y values arrays to simulate your different acquisitions. Somebody will fix that with you.
Chilly Charly    (aka CC)
(3,108 Views)
Hi, thanks for replying.
I mean something maybe quite simple as this. please see attachement. i use labview 6.0.2
it simply has to give ture one time and the rest of the time false, but i can't figure it out, also tried with shift registers.
Thanks for all the help.
(3,085 Views)
That should work.
Message Edité par chilly charly le 11-06-2007 02:25 AM
(3,070 Views)
OK that's fantastic i will study how you did it en try it right away.
Thanks for all your help and i will let you know if it worked.
Thanks, merci.
(3,060 Views)
