10-19-2007 03:49 PM
10-19-2007 05:31 PM
10-19-2007 05:40 PM
10-20-2007 04:51 PM
10-22-2007
01:40 PM
- last edited on
05-21-2025
03:18 PM
by
Content Cleaner
Hello jackmaker,
First of all, welcome to the NI discussion forums! There are some other things to try before it comes down to formatting your computer. The reason you are seeing this behaivior is that the system is detecting a more recient version of the driver on your computer (which was probablly installed when you installed LabVIEW 8.0 or 8.2).
In order to use NI-DAQ 6.9.3, you will have to get rid of these later drivers. The trick is that you have to remove any other drivers that has dependancies on the version you currently have as well (e.g NI-DMM, or NIFGEN can have this kind of dependancy). Give this a try and post back to let us know how it goes!
10-22-2007 06:16 PM
Thanks. That is the knowledge base note that I was working off of. The problem is that there weren't any NI-DAQ components to uninstall listed in the control panel. So I couldn't remove any of the newer NI-DAQ driver bases.
I've probably completely messed up now, but I decided to perform an 'um' manual uninstall. I deleted everything from the Program Files\National Instruments subdirectory. I also went thought the registry, using regedt32, and removed all references to anything with "labview" or "national instruments". After doing the later, I was able to install 6.9.3, but when I start Measurement & Automation explorer, it fails complaining that the "config" file is corrupt. I deleted the file, re-ran Measurement & Automation, it rebuilt config, but still complains. Re-installation of 6.9.3 didn't do any good. I installed Labview 8.0 again, but didn't get anywhere with that. I guess I can try installing NI-DAQmx again.
The basic problem is that that knowledge base note doesn't seem to cover a situation where the National Instruments software isn't listed in the control panel uninstallation list. I'm still wondering why it wasn't listed there, but that's another question...
10-22-2007 08:23 PM
10-23-2007 09:33 AM
10-23-2007 04:23 PM - edited 10-23-2007 04:23 PM
Message Edited by Neal M on 10-23-2007 04:24 PM
10-23-2007 04:49 PM
