clear array
Helo,
I have a question about arrays. I want to place every 2 hours a value in an array. After 24 hours (1 day), the array must be cleared for placing new values in the array. The values must
be placed on index 0 till 11. When i clear the array, the differnt values in the array are changed to 0 ( I use Initialize Array ), but instead of starting from index 0 it starts from index 12.
This repeats itself every time i start a new day. As a result the array size will keep growing instead of staying between 0 and 11
Grtz
Message 1 of 9
(5,008 Views)
Hi Jurgen,
if you would use InitializeArray then you should get an empty array of 12 elements.
But from your description I would suspect there is a BuildArray somewhere in your code...
So to solve this mystery it would be best to actually see your VI!
Message 2 of 9
(5,004 Views)
Hi GerdW,
This is the problem area. I hope you could see enough.
Message Edited by JurgenV on 05-08-2010 01:13 PM
Message 3 of 9
(4,994 Views)
Hi JurgenV,
I don't see any InitArray node... Only some locals and uninitialized shiftregisters Smiley Wink
Message 4 of 9
(4,976 Views)
Hi GerdW,
You are right. I'm a new user of LV. The InitArray is placed in a true case of a case structure
Grtz
Jurgen
Message 5 of 9
(4,956 Views)
Hi JurgenV,
the problem is located in the general overuse of locals...
Well, you clear the array by writing to it's local. BUT: there is a feedback node, which keeps the last value for the next iteration! And this feedback node isn't cleared too! So think about dataflow and redesign your VI Smiley Wink
Hint: join frame 1 and 3 of your flat sequence (counting starts with 0) into one frame to get rid of that local. Feed the feedback node with the same value as the array indicator...
Message Edited by GerdW on 05-09-2010 10:58 AM
Message 6 of 9
(4,953 Views)
Hi GerdW,
About clearing the feedback node. When I use the debugger I noticed the "index" of the feedback node isn't cleared. Is there a possibility
to clear it.
Grtz
Jurgen
Message 7 of 9
(4,942 Views)
Hi GerdW,
I think I have a solution, may it isn't the best solution but it works. Every time there are 12 values in my array the array will be cleared and the index of my shift register start by 0.
Jurgen
Message Edited by JurgenV on 05-09-2010 06:27 AM
Message 8 of 9
(4,927 Views)
Hi JurgenV,
you nearly took my advice:
When you connect the "2hrs array" indicator with the output of the Select function you can get rid of the last frame of the sequence and so forget about that local...
Message 9 of 9
(4,911 Views)
