Can't figure out why FPGA code won't compile, says files are missing
Hey guys, I get the following error, sorry for the big vomit of error code. As near as I can tell from reading that, it thinks a number of the files it requires to run some of the subvi's I'm calling are missing. I don't understand how to fix this when these are LabView native files, for example, the high-throughput rectangular to polar converter?
Help much appreciated.
Error code follows:
Error 7 occurred at Open VI Reference in nirviOpenVIRefByNameOrPath.vi->niFpgaRemapObjsAndListIfUnderXNode.vi->niFpgaRemapObjsHandleXNodeSubErrors.vi->nirviMassageErrorList.vi->nirviParseAndMassageErrors.vi->nirviReloadErrorList.vi->nirviGenerateErrors.vi
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
VI Path:
All text parsed:
<CodeGenErr>
<ErrorCode>-61160</ErrorCode>
<DynamicText><TreeLineInfo><LineInfo><DiagramObject><VIPath>C:\NIFPGA2009\clntTmp\FPGAImagi~2C_FPGATarg~A7_2Tap8bit~6A_nagEfsCz~08\MungedForFPGA\NI.Munge.2 Tap 8 bit RT Image Processing Initial.vi_FPGACompileCopy00000001.vi</VIPath>
<UID>5485</UID>
<ObjectName>High Throughput Rectangular To Polar</ObjectName>
</DiagramObject>
</LineInfo>
</TreeLineInfo>
</DynamicText>
</CodeGenErr>
<CodeGenErr>
<ErrorCode>-61101</ErrorCode>
<DynamicText><TreeLineInfo><TreeInfo><TreeID>1</TreeID>
</TreeInfo>
<UID>5036</UID>
<ObjectName>SubVI: &apos;Butterworth Filter&apos;</ObjectName>
</DiagramObject>
</LineInfo>
</TreeLineInfo>
</DynamicText>
</CodeGenErr>
<CodeGenErr>
</TreeInfo>
<LineInfo><DiagramObject><VIPath>C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\rvi\Analysis\utilities\niFPGA I32xI32 Dot Product - 3 elements I64.vi</VIPath>
<UID>63</UID>
<ObjectName>Timed Loop</ObjectName>
</DiagramObject>
</LineInfo>
</TreeLineInfo>
</DynamicText>
</CodeGenErr>
<CodeGenErr>
</TreeInfo>
<UID>5036</UID>
</DiagramObject>
</LineInfo>
</TreeLineInfo>
</DynamicText>
</CodeGenErr>
<CodeGenErr>
</TreeInfo>
<UID>5036</UID>
</DiagramObject>
</LineInfo>
</TreeLineInfo>
</DynamicText>
</CodeGenErr>
(3,745 Views)
GotRobotFriends,
Hello! First of all, can I get the following information from you?
1.) LabVIEW and LabVIEW FPGA Versions
2.) FPGA Target you are trying to compile code for.
Typically errors 61101 and 61160 are thrown when a Single Cycle Timed Loop (SCTL) has elements within it that won't allow it to finish it's execution in 1 clock cycle.
Looking through the error codes below, do you have any of the following items in a Single Cycle Timed Loop?
  • High Throughput Rectangular To Polar
  • Butterworth Filter
Also, are you using xnodes? Problems have been seen when items that would normally return an error when placed in a SCTL do not return errors if they are used with xnodes.
Ben Sisney
FlexRIO V&V Engineer
(3,713 Views)
Hi Ben
Yes I have both those inside a single cycle timed loop. I was under the impression that they  introduced a latency rather than throwing an error. No I'm not using xnodes, I'll have a look through the help, could you give me a quick run down on what they do?
Regards
Alex
(3,695 Views)
GotRobotFriends,
If you look at the Help or the FAQ for Single-Cycle Timed Loops (SCTLs) there are lists for the items that are not allowed in SCTLs. The Butterworth Filter is on that list, however, at first glance I don't see the High Throughput Rectangular To Polar function. Would it be possible to convert your SCTL to a while loop and see if that resolves the compilation failure?
Also, can I get the following information?
Ben Sisney
(3,670 Views)
Labview 2009, attempting to compile for a pxi-7951R, I'm not sure exactly which labview FPGA version I have but I think it's pretty recent. Yes I have removed the butterworth filter and the high throughput rectangular to polar, I'm now doing the rectangular to polar manually spread out over a couple of loops.
regards
Alex
(3,653 Views)
GotRobotFriends,
Did removing the butterworth filter and high throughput rectangular to polar allow you to now succesfully complie your FPGA code?
Ben Sisney
(3,634 Views)
Hi Ben
I removed the butterworth filter, and set up the rectangular to polar correctly  and it's now compiled. Cheers
Alex
(3,599 Views)
