clear a text file
hi need help
how to clear the content of the text file with out delete the text file
Message 1 of 8
(4,319 Views)
Try using the Open/Create/Replace fucntion, set it to Create or Replace, then just close the file without writing any new data.
Message 2 of 8
(4,318 Views)
i cant get it
let say i have tis c:\\abc.txt
aftr  tht i copy the text to another destination
the text file in c:\\
should be cleared all the content of abc.txt
can u give some exmple plz?
Message 3 of 8
(4,311 Views)
HI jeyanthi
here with i attached the file...see this .. enter the file path and run ......i hope its helps u............
Indrajit
| indrajitbarve@gmail.com | indar_indar2005@yahoo.co.in .
Message 4 of 8
(4,309 Views)
hi im using labview8.0 cant open the 8.2.can u paste the .png of the block diagram .thk u
Message 5 of 8
(4,303 Views)
Hi jeyanthi,
this is the part you need.
Mike
Message Edited by MikeS81 on 06-05-2008 10:39 AM
Message 6 of 8
(4,298 Views)
here is the file see
Indrajit
Message 7 of 8
(4,291 Views)
thk u its helps
Message 8 of 8
(4,283 Views)
