clean up registered computer
I registered computers to use shared variable (see attached file). I want now to clean up this lists... how can I do that ?
Paul
(2,776 Views)
Anybody has a solution ?
(2,744 Views)
Hello Paul,
There is a way to do this, although it involves editing registry keys which we don't recommend.  If you would like to do this to delete a registered computer, go to Start >> Run and type in "regedit" to open the Registry Editor.
Navigate to HKEY_LOCAL_MACHINE >> Software >> National Instruments >> Lookout >> 4.0 >>Machines.  You should see the machine names or IP addresses that you registered to use Shared Variables.  Delete these machines and they should be removed from your list of Network Items.
Clint M
(2,715 Views)
