class conflicts and Looking for VIs from old .lvlib
I simply renamed the file (e.g. from A.lvlib  to B.lvlib) without updating the internal references, LabVIEW will still look for the old library name (A.lvlib), causing class conflicts. Looking for VIs from A .lvlib. How can I solve this?
 Thank you in advance
(598 Views)
Hi 123,
Yes, that's correct.
By NOT renaming files on disk.
Rename the lvlib from within the project explorer…
(596 Views)
i already renamed it now. and thats the reason im facing the problem adn if i going back to old name its showing the same error.
(580 Views)
Hi 123,
Simplest solution: get an older, but working revision of the code from your SCC system!
Spoiler
In case you don't use any SCC system yet then you have learned about the importance of using one! 🙂
(558 Views)
