Sine Generator output using 7846R analog output
Not sure if this is the proper board for this particular post, apologies if not.
I wanted to use the Sine Wave Generator vi to drive two analog outputs on the 7846R series PXIe card but I am not sure what I am doing wrong or not understanding. Below is some very simple code. Amplitude output is set to full scale, and I was just trying to divide down the output to ultimately get the amplitude I wanted.
Do I have a data type issue by chance? Generator says output is an I16 so I converted to fixed point because that's what the r-series card wants. Code compiles fine but one output (AO0) does nothing and the AI0 output looks like a square wave on my scope and frequency is way off.
(769 Views)
Accepted by topic author cabala
You can configure your AO channels to receive raw mode. See Working With Calibrated and Uncalibrated Data on NI R Series
https://tmesystems.net/
(715 Views)
Interesting, much appreciated for this reference link. While I am new to R-series FPGA and don't follow everything in that article it seems for my quick application (which does not require a host interface) I just need to change the AO to raw mode. I'll give that a shot later today when I can get back to the lab.
I did find the Analog Sine Generation example for R-series cards in the built-in examples and that was helpful, but it does not actually output the data to a physical pin. It generates the sine wave on the FPGA but then passes it back to the host and just plots it. I tried adding an actual analog output node and tied the data to it before it gets passed back to the host, but I got similar results as my little program so hopefully updating the outputs to raw mode fixes this.
Interestingly enough, the output does work as expected when simply using a control and setting the output to a constant (DC voltage). Any idea why calibrated vs raw mode would not affect a DC output vs an AC output?
(702 Views)
Thank you again for this recommendation, that helped tremendously.
I am getting a perfect 2kHz sine wave output on AO1 at full scale and dividing it down allows me to set the amplitude to any level.
Also, I modified the code slightly as shown below because I am still not getting anything out on AO0 and I don't understand why. I thought maybe the sine generator couldn't drive two output connectors at the same time so I added a second generator vi but that didn't fix anything. I am using the SCB-68A connector block with an RMIO cable, and I have double checked the pinout against the 7846R card at least ten times.
Thank you in advance for any additional tips you might be able to provide. I will add AO2 through AO7 and double check that those output as expected as well.
(684 Views)
Just to follow-up, I ended up re-wiring the code, recompiling, and for some reason that fixed the issue on AO0. Not sure why but now all eight outputs are working when set to "raw" mode.
(640 Views)
