circle LED
Hello everyone 🙂
please I need to know if anybody had done before an algorithm or a vi that ,given the value of the radius, can display a circle using leds (boolean terminal) in LabVIEW like the picture in the attachement
Message 1 of 18
(5,545 Views)
No.  But you ought to be able to do it with a 2-D array of booleans, and some simple math using the index values to determine whether a boolean should be on or off based on the equation for a circle.
Message 2 of 18
(5,537 Views)
you might use a 2D picture for that purpose: draw a circle in a picture and display it in a picture indicator. If you really need to use an array of LEDs you can convert that picture to a black/white pixel array that in turn will be displayed by your array indicator:
Message 3 of 18
(5,533 Views)
Accepted by salah_m7
Hi salah_m7,
you're looking for something like this?
ok, GerdW was quicker ...
Message 4 of 18
(5,523 Views)
Thank you for all your answers 🙂
but I have LabVIEW 2010 I can't open LabVIEW 2011 files, I've tried to build a block diagram like you've mentioned in the pictures but I've some errors & I don't know why (in the bundle I can't put the cluster control)
Message 5 of 18
(5,499 Views)
Hi salah,
use my snippet...
Message 6 of 18
(5,496 Views)
Thank you GerdW 😄
Thank you for the link 🙂 , this is the first time to use a snippet
Message 7 of 18
(5,482 Views)
I'm sorry, I've understood that we can convert a snippet to a vi xD
I've the same problem with the code because i can't put an empty cluster, if I create a constant cluster it came with 4 integers
Message 8 of 18
(5,473 Views)
Hi salah,
the snippet has known problems with cluster constants. That's why I wrote my comments next to them...
Message 9 of 18
(5,473 Views)
@GerdW wrote:
Hi salah,
use my snippet...
o_O I never knew about this ... ! this is such a great feature!
Message 10 of 18
(5,456 Views)
