checksum
I have to calculate the checksum using the function below. I am new to Labview and my c skills is a little rysty. Please help.
Thankyou.
24 bit  = 00001 + 0000000000000000000
Var1 (5bit msb)
Var2 (19bit)
Encoded little endian 32 bit from 0x1FFFC to 0x1FFFF
uint32_t checksum8(const void *buf, uint32_t length)
uint32_t n, checksum=0;
uint8_t *p = (uint8_t *)buf;
for (n=0; n <length; n++)
checksum += *p++;
if (checksum > 255) checksum -= 255;
return (~checksum&0xff);
Combined number = checksum * 16777216 + Var1 * 524288 + Var2
Message 1 of 11
(5,441 Views)
Hi labvcj,
here's the inner loop to give you a starter:
Message 2 of 11
(5,412 Views)
I'd use a quotient and remainder
"Should be" isn't "Is" -Jay
Message 3 of 11
(5,394 Views)
Hi Jeff,
this is what the OP wants to implement:
I thought so too at first, but what would be the result when checksum is equal to 255?
Message 4 of 11
(5,377 Views)
Hi Jeff,
some more explanation (too late to edit previous post):
- "(checksum > 255)" refers to a Q&R with 256 as divider…
- "checksum -= 255" refers to a Q&R with 255 as divider…
Message 5 of 11
(5,368 Views)
Seems like a strange choice of algorithm for the checksum.
In a normal world, for an 8 bit checksum, you would get the byte array and use sum array elements on it (the result would be limited to 8 bits and would all be fine).
In this case, each time you overflow the 8 bits you effectively need to discard the overflowed bit add 1 to the checksum.
It doesn't add any robustness to the checksum algo, and feels to me like a mistake.
How sure are we that the c++ code actually works?
0xDEAD
Message 6 of 11
(5,355 Views)
@GerdW wrote:
Hi Jeff,
Sorry,  I should have been specific.  Tha line is equivalent to
     checksum = 256 mod (checksum);
Or, just use a U8 😄 and no math required.
You know where to post your example.
Better you than Christian.  😄
Message 7 of 11
(5,340 Views)
Hi Jeff,
I don't get your math…
How is
equivalent to
Example:
checksum := 270 (before math routine).
Your result: checksum = (256 mod 270) = 256
OP wanted: checksum = 270-255 = 15
Message 8 of 11
(5,334 Views)
256 mod (270) is 14. Modulus is the remainder of the dividend ,270 / divisor, 256.
My C++ may be rusty but,  is that a bad thing for a  LabVIEW guy?
Message 9 of 11
(5,331 Views)
@GerdW wrote:
Hi Jeff,
How is
equivalent to
Example:
Jeff's nomenclature is backwards.  It really should be:
checksum mod 255
That would match what the OP stated.  If you just add bytes and ignore the overflow (the way much checksums work), it would be a mod 256.
Message 10 of 11
(5,327 Views)
