check box invert the pulses
How can I code a check box that will invert the pulse.
(3,210 Views)
Just wire it to a case structure that inverts the pulses.  That's a pretty generic answer but that's what you get when you post generic questions.  Can you be more specific about your application and what you've tried so far?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,205 Views)
What pulse?
A check box is a boolean.  Use it to drive a case structure.  Depending on the way this pulse is constructed, you should be able to mathematically invert it.  for more help, you'll need to provide some details.  Perhaps even attach a VI showing what you've done so far.
(3,203 Views)
Something like this?
=== Engineer Ambiguously ===
(3,179 Views)
