changing he color of the front panel control programatically
        I want to change the colour of the control(Numeric control) on the front panel programatically.Like, if the value from the numeric control doesn't set on the specified instrument then the colour of the numeric should turn into "red" otherwise "green".How can I go about it?
Regards
RobinHood
Message 1 of 15
(3,987 Views)
Hi vipull,
you can use a property node to do it. See the attached example.
Mike
Message Edited by MikeS81 on 07-23-2009 07:37 AM
Message 2 of 15
(3,983 Views)
Thanks Mike
Regards
RobinHood
Message 3 of 15
(3,963 Views)
    I want to  change the back ground color of the numeric control as per the conditions.like if the frequency range is between 2000 and 5000 it should be in green color, it it is in between 6000 and 10000 it should be in red color.I've attached my vi here. plz find it.
Regards
RobinHood
Message 4 of 15
(3,955 Views)
here I hope this helps:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 5 of 15
(3,948 Views)
thanks Harold
Regards
RobinHood
Message 6 of 15
(3,937 Views)
it will be more efficent this way:
no need for the value property node:)
Message Edited by Harold Timmis on 07-23-2009 07:20 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 15
(3,933 Views)
Harold posted ...
or....
use an "in-range" node to do the same work as the compares and And gate.
Ben
Message 8 of 15
(3,917 Views)
Harold,
            I want to stop running the vi if red back ground comes.can i do that.
Regards
RobinHood
Message 9 of 15
(3,902 Views)
Ben,
       where canI get this in-range node
Regards
RobinHood
Message 10 of 15
(3,899 Views)
