changing file name after every integration of for-loop
I am trying to run 1000 iteration of for-loop. After every iteration, I save the output (matrix) into a file. I want to update the file name such that after first iteration the file name is reflectance1.dat and after second iteration, reflectance2.dat and so on....How can I program this to be done automatically in labview.
(3,864 Views)
Use the "Format Into String" function:
Message Edited by smercurio_fc on 03-17-200610:06 AM
(3,859 Views)
Hi
You  can use the i in the for loop to make a file name for you with the number in the end and then add it to the name of the file.
See the attached png file for explanation.
Regards
Nitin
(3,855 Views)
