03-16-2006 02:58 PM
03-16-2006 07:00 PM
03-17-2006 07:25 AM
03-17-2006 08:22 AM
03-17-2006 09:39 AM
03-17-2006 10:02 AM
By the way,
In the RevHistory.png, could you possible identify/describe the icons? Since they aren't within an accessable VI, I'm not sure what all is going on there.
03-17-2006 10:12 AM
Look on your Application Control palette.
Personally, I find the revision history a poor method of source code control. Anyone at anytime can reset it and even if you select the properties to force a comment or a new entry even time it is saved, this too can be turned on or off by anyone. I'm not sure if it's changed in LabVIEW 8, but the revision history reports 0 for a VI built into an executable. With real source code control tools available free of charge, that's what I would recomend.
