changes in labview vi
Dear all,
I use the "path" to define the  file location. However, when I can changed the value for that "path", I saved it. The program told me it is saved.
However, next time, when I open the VI, it is still the old value. What's wrong there?
Thanks.
(2,881 Views)
In order to save a change in a value of a control, you have to go to the edit menu and select 'Make Current Values Default (or Make Selected Values Default). Then you do a save.
(2,868 Views)
Accepted by topic author RoyOfAgent
thank you very much. I got it.
(2,865 Views)
