03-01-2007 10:18 AM
03-02-2007 02:33 AM
hi martin,
Are you plotting data on a Graph or Chart? How about attaching a simple VI along with some data.
Cheers!
03-02-2007 03:18 AM
Okeej,
The attached vi reads the trace date that is in file moi (witch is also attached)...
What i want to do is that the trace starts at 150000 (khz) and stops at 110(MHz) instead of starting at 0 and stopping at 400....
03-02-2007 08:29 AM
03-02-2007 08:44 AM - edited 03-02-2007 08:44 AM
At the very least, you have to save the start frequency and increment in the data file along with the Y data. When you read the start and increment from the file, then you can write these to the a graph's offset and multiplier with a property node.
Saving the x axis as an array will also work as Gerd mentioned.
Message Edited by Dennis Knutson on 03-02-2007 07:44 AM
03-02-2007 08:47 AM - edited 03-02-2007 08:47 AM
Of course you now should label the Axis Hz.
Message Edited by altenbach on 03-02-2007 06:51 AM
03-02-2007 08:58 AM - edited 03-02-2007 08:58 AM
Message Edited by altenbach on 03-02-2007 07:01 AM
