change the format of a string
Hello all,
Now what shall I do is to convert a string to an array.
The string I got is shown in the pic in attachment, together with my code.
Obviously the array isn't correct.
i wonder if there's a way to change the format of the string without the empty lines, and concatenate each number after another,
in order to have a correct array with my code.
Or someone has idea to make a new code for converting a string like this to array?
Chao
(3,402 Views)
Hi Chao,
1. Use SpreadsheetStringToArray with a comma (or NewLine) as separator...
2. Attach your VI instead of a picture. So we would have the option to edit the VI...
(3,397 Views)
Spreadsheet String to Array
<edit> Race condition.  I lost to GerdW.
Jim
(3,393 Views)
Hi Gerd!
Here is my VI. Actually I figured out a simple way to implement this, just by
adding a Trimwhitespace.vi between the input string and match pattern, and that works!
I'm still glad to know how do you use spreadsheetstringtoarray.
Thanks in advance if you can show me that!
Chao
(3,359 Views)
Accepted by topic author jcraffael
I think they are referencing something like this.
(3,346 Views)
Wonderful! That's it.
Thanks a lot for the reply!
Chao
(3,339 Views)
