change numeric format type under edit limits from Labview
is it possible to change under Edit Limits the numeric format type (Hex, Decimal, Real...) from LabView?
Is there any way to change this types from Labview. Because i can't found an variable like step.result.numeric or what ever.
I hope somebody know what i mean.
thank you and best reguards
Message 1 of 15
(4,613 Views)
I don't understand your "Edit limits".
Where do you find this?
Message 2 of 15
(4,585 Views)
If you use an Numeric Limit Test in Test Stand. Then you can set with the options by right click edit limits.
In this edit limits menu you have a button numeric format. An here you can change the Typ in Hex, decimal and real.
How can i change this options for this step from labview?
Message 3 of 15
(4,575 Views)
Hi Tumbler,
generally I would say that is is possible to access the numeric format type, but it would be difficult to find look up string.
May I ask what makes you need this? Normally you would receive your Data Type from a VI and via preconditions you can choose what limit test is the the right one for your result.
Stefan Henke
NIG
Message 4 of 15
(4,563 Views)
Please see this Nugget for a possible solution.
Benn
Message 5 of 15
(4,559 Views)
ben that what you show me is how i change the format in the Vi. But this format i have in the vi i will gave back to teststand and want to change under edit Limits the typ from decimal to real oder hex or what ever.
Message 6 of 15
(4,549 Views)
Hello Stefan,
i would like to do this because we have create a config vi. And the people for this we made this step don't want to change in Edit Limits and the configuration for the device in the config step.
Thats why we want to do this from this vi.
Message 7 of 15
(4,544 Views)
Hi Tumbler,
Within the TestStand Sequence Editor for a step which has limits, then on the Edit Limits dialog should be a control which will allow you to change the format which is set to <default>. I think you might have to click on another button which will bring up another dialog which will allow you to change the format. ( I haven't got testStand to hand at the moment, so I am working from memory).
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 15
(4,542 Views)
Yes i know that i can change the format under edit limits but i want to change this from a labview vi.
For example i have a button in Labview with this button i can change the format from decimal to hex.
An then i want set this change to TestStand.
I want to change all parameters in Edit Limits from LabView
Message 9 of 15
(4,533 Views)
... Edit Limits from LabView
I am confused.
The format can be changed using the info in the Nugget to which I prviously provided a link.
Ben
Message 10 of 15
(4,526 Views)
