change numeric format type under edit limits from Labview
Are you saying that you wish to do the same thing as on the Edit Dialog but under program control via your VI code module, eg using a TestStand API method or property?
Ray Farmer
Ray Farmer
Message 11 of 15
(1,045 Views)
Hi Ben,
you change the format in LabView vi. I want to change the format from LabView for an numeric Limit Test in TestStand.
In my Attachments you will see what i mean. I will change the real Typ to Hex for Example. And this i will do from Labview.
Message 12 of 15
(1,033 Views)
Hi Ray Farmer,
thats what i want to do!
Best Reguards
Tumbler
Message 13 of 15
(1,034 Views)
You can use the property PropertyObject.NumericFormat to set the format of a property such as the Numeric or the Limits.High. Check the programmer reference help for the format of the format string.
Hope this helps
Ray Farmer
Ray Farmer
Message 14 of 15
(1,010 Views)
Thank You,
can you send me an example?
Message 15 of 15
(997 Views)
