change data from keyboard ( ex: a ==> numeric = 15 )
i want to make a simple Piano ... i got note equivalent frequency and i did a numeric case that pass one frequency to the wave output so changing the numeric simulate piano
i only could set decrement/increment from the keyboard  for numeric value  this is not efficient
i want to simulate the keyboard as a physic piano so when clicking 'a' correspond do ... this mean that i want to change on clicking 'a' the numeric value to 0
the project is attached
Message 1 of 12
(3,548 Views)
Hi jasjas,
use an event structure to detect keypresses. You will get an ASCII code for the key that you have to convert to your frequency.
You can directly connect it to a case structure where you define a frequency for each relevant key. Or you use a lookup table...
Message 2 of 12
(3,546 Views)
Hi jasjas
i add an example for you with the suggested Event Structure. (thanks GerdW)
Mike
Message 3 of 12
(3,537 Views)
Sorry Mike but ur example won't open with me can u plz save to Open with labview 8 i don't have labview 8.5
Message 4 of 12
(3,520 Views)
Hi
yes of course. Now in 8.0
Mike
Message Edited by MikeS81 on 01-21-2008 12:55 AM
Message 5 of 12
(3,500 Views)
You Save it on 8.2 still will not Open with 8.0 😞
Message 6 of 12
(3,462 Views)
Hi jasjas,
i´m sorry. I hope it is now in 8.0.
Mike
Message 7 of 12
(3,457 Views)
Still Get Errorr!
Message 8 of 12
(3,449 Views)
Here's the 8.0 version.
Message 9 of 12
(3,444 Views)
Hi
i´m so sorry. I think now i have it.
Mike
Message 10 of 12
(3,441 Views)
