01-25-2008 02:03 PM
I'm using the code shown in the sample VI discussed here: http://digital.ni.com/public.nsf/allkb/353A696A3F393D9B86256E8B007A2912
to close all open
Thanks!
01-25-2008 02:44 PM
01-25-2008 02:49 PM
01-25-2008 03:55 PM
If you need them as separate .exes you could pass shared variables between them. I am doing this with a watchdog app that runs by itself and if the main LV.exe application crashes, will reboot the computer. This technique both over a network only on a standalone machine. I beleive this requires LV8.5 though.
If you decide to use one vi I would recommend make parallel while or event cases to run the subpanels - build as one '.exe' application.
01-25-2008 03:59 PM
Where do I begin…..
I’m using a “server” to control 4 “client” PCs. My server opens references to 4
We are updating from LabView 6.1 to 8.5 and we want to run executables rather than
01-26-2008 12:50 PM
