case structure with integer selector
How can I put a case structure with an integer selector on the block diagram?  It seems there is no
way to change a case structure with boolean selector to an integer one.  Any suggestions?
(13,333 Views)
Just wire an integer to the selector terminal. It will adapt automatically ðŸ™‚
(13,331 Views)
You can then use different syntaxes to set the cases.
Some examples :
  • 1..10 --> 1 to 10
  • -1,5,7 --> -1,5 and 7
  • ..5 --> values less or equal to 5 --> 0 to 5 for an unsigned integer and -Inf to 5 for a signed integer
  • 5.. --> values greater or equal to 5
  • 25, Default --> 25 and all values that are not set in the other cases
Search the LV help for "case structure".
(13,311 Views)
On Nov 15, 3:10 am, WeiC <x...@no.email> wrote:
> How can I put a case structure with an integer selector on the block diagram?&nbsp; It seems there is no
> way to change a case structure with boolean selector to an integer one.&nbsp; Any suggestions?
just wire a integer control to the selector structure. It changed to
integer. After that you can add more cases and modify then......
(13,237 Views)
