case structure selector values
   I have placed a case structure on a block diagram and have created numerous case values. Is there a way that I can right click on the selector and get all of the case values assigned to a control that I can use to pick all of the case that I have defined?
Kaspar
(4,193 Views)
What exactly do you mean? Clicking on the selector label lists all of the cases.
(4,188 Views)
  You are right when you click on the selector label. I would like to click on the "Case Selector" (the little box with the question mark) and get all of the case labels/values put into a control
Kaspar
(4,182 Views)
Accepted by Kaspar
You have kind of done it backwards from the way most people do it.  Most people create the control, then add the case structures.
You may want to look at this thread at a utility someone wrote to do what you ask.
(4,179 Views)
