case structure question
say i have 3 case structures one within another.. say i want to create a new case structure over all these exisiting case structures. so you have true and it shows each of the case structures etc. when you go to false, all them existing ones within now disappear.
my question is there anyway, that say when you switch to false, the exisiting structures show up, like under the default true
thanks
(4,280 Views)
I am not sure if i understand your question.
My understanding is that you have elements (e.g. nested case structures) in a specific case of your outermost case structure. Your request is to make these elements visible in other cases of your outermost case structure as well.
Why should i do so? How should the nested structures be marked as such that the developer understands that they are NOT part of the currently visible case?
Do you want to see the COMPLETE content of EACH case at any time?
If you walk through above questions, i hope you understand that this is not going to happen. Case structures are currently already "difficult" as you only see a small excerp of the complete code. But adding all code into some weird display would make confusion even more severe. Just think of a case structure covering almost a complete monitor resolution and about 50 different cases........ that would be blank horror to review.
Maybe you can create a small example on how you think this should look like....
Norbert
Norbert
Expert: Geometry
(4,277 Views)
Accepted by topic author pjh-10
R-click and Duplicate the True structure, remove the extra False.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,256 Views)
If you want the existing Case structures in both cases of the new structure, delete the False case and duplicate the True:
If you just want the existing stuff in the False case, select "Make This Case False".
Jim
(4,252 Views)
yeah thats it
(4,212 Views)
