Hi All...
I've another questino to submitt
We want to cascade a SCXI 1125 (isolation/gain), and a SCXI 1143 (low pass filter). To do this, we will use a SCXI 1352 cable.
1) First problem : I read in a NI document, that this configuration is only partially supported (only with NI DAQ ) ... I that true ?
2) Another configuration that support DAQmx is a SCXI 1120 cascaded with a SCXI 1143. The problem is the gain of the SCXI 1120 is selectable by jumper (not with software ...)
3) What configuration will allow me to use DAQmx and to set the parameter of each card individually through software ???
Thanks for your future answers .... !
