Trigger and Gate
Is there any option for not using the Express-VI -Trigger and Gate-, but having the same result?!
It is because i am at programming a VI for my PDA at LabVIEW 7.1, but there it is not available!!
I only need it for defining a Trigger Signal, so there has to be another solution...
Thanks for every help!!!
Thomas
(5,149 Views)
You can convert the express VI to code and see if that works on the PDA, if not there are probably some OS dependend pieces of code used in the express VI's code and you will have to replace that by code accepted by the PDA platform.
André (CLA, CLED)
(5,141 Views)
There is a Basic Level Trigger Vi in the Analysis Package. I think you need at least a FDS for that.
Felix
(5,138 Views)
