capture images
Hello Sir and Maam!
i am an engineering student. i have a problem, i want to take pictures form labview using my built in camera in my laptop. I have read many discussions hwo to use it.. I downloaded Ni Imaq, Visa, Vision Assistant too but in the end my built in camera is not supported to capture images. I need to do it but after searching some cameras that Labview is compatible it is too much costy for me.
to make that story short i found an example program that makes me allow to use of my built in camera. I'll attatch it here. But i want to ask a favor on how to add some codes to capture image. it is just using a express vi.
I'll attatch the code! tnx maam and sir!
-hoping for your help
Example Grab Express.vi
(3,209 Views)
Accepted by topic author Mr_ask
@Mr_ask wrote:
Hello Sir and Maam!
check this vi i made to snap and save image. You can use MAX to get camera name or to configure them too.
(3,188 Views)
hello sir! thank you for a wonderful code. What you told me about MAX helps me a lot. tnx! but sir i have a little problem the program that you have made have a little problem. or i just dont know how to do it. i cant save the image that i want. But by the thank you so much sir!
You are the great!
-Studying makes you perfect
(3,164 Views)
Sir AnkitG. Thank you! i have done it already. I just change the selection setting by folder not by file. Thank you so much again Sir AnkitG!
I hope i can ask you again next time for our project.
-thanks again!
(3,158 Views)
