08-21-2013 12:22 PM
Hi i have and elvis II and running it using labview 2012 and im trying to get a switch in order to be able to start and stop the function by using a boolean.
Any help is appreaciated
Thanks in advance
08-22-2013 09:10 PM
Thank you for posting on NI Forums. Maybe you could try using an event structure to trigger the express VI to start running? Then, the same boolean could be used to stop the VI. I don't have an NI ELVIS with me to test this out, but I tried to modify your VI to implement this. I hope that this at least points you in the right direction.
Jeremy P.
