09-25-2003 06:58 AM
09-28-2003 06:28 PM
09-29-2003 09:09 AM
05-15-2008 03:45 PM
Hello!
I am facing a similar problem. I am trying to broadcast sound using datasocket. One program "sound_input.vi" is to write sound to datasocket server, and another is "sound_output.vi" to read sound from datasocket server. The sound_input is executed on the same computer where datasocket server is running, hence the url is to "localhost" and the sound_output specifies url of the datasocket server's computer. (normal datasocket programming)
When I run both these programs on the same computer, there's no error, and I read sound (and infact hear too) perfectly. But, when the sound_output program runs on another computer, I see an error at the computer running sound_input and datasocket server.
Error 4823 occurred at Sound Input Read (DBL).vi->Sound_Input.vi
LabVIEW: (Hex 0x12D7) A task must be running to perform this operation.
My network connections are ok, since I can run my video input/output application using datasocket server, between these two computers.
I have attached two program block diagrams for further information.
Any clues?
Thanks ahead.
-Vaibhav
05-19-2008 01:07 AM
05-20-2008 05:57 AM
05-20-2008 06:09 AM
What version of labVIEW you are using?
Mathan
05-20-2008 06:32 AM - edited 05-20-2008 06:33 AM
Am using LabVIEW 8.5 and couldn't able to find the vi you mentioned. [ DS Weather.vi]
Mathan
05-20-2008 08:55 AM
07-10-2008 11:37 AM - edited 07-10-2008 11:39 AM
