cant insert subvi
I dont know what I did, but I can no longer insert a vi into a vi when I select "select a vi" from the functions palette (or any other way.)  When I do this the open vi window opens and I can select a vi to insert, but when I hit ok the current vi's window blinks twice and the vi i selected isnt inserted.  What did I do?
(3,507 Views)
Did you try another VI?
If the VI you are trying to insert is corrupted, that could explain the symptoms you described.
Ben
(3,501 Views)
I've tried other vi's.  I've tried making brand new, simple vi's. I've tried restarting the computer...
(3,496 Views)
Does LabVIEW ask you to investigate the error at startup? Or, did you turn that option off (it's in the "Debugging" section of the LabVIEW options). Did you get an error log (it should be in your "LabVIEW Data\lvfailurelog" in your personal Documents folder)? Have you tried to do a repair on the LabVIEW installation?
(3,457 Views)
Is the file write protected? (brainstorming)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,437 Views)
What version of LV are you using? What kind of license (Base, Full, Professionell)?
Does this also happen when placing VIs already available on the function palette like e.g. "Write to Spreadsheet File.vi" in the File IO palette?
Norbert
Norbert
Expert: Geometry
(3,423 Views)
