cannot stop while loop
I want to count how many times the Boolean state has changed. But somehow the stop button cannot abort the statement.
Message 1 of 8
(5,852 Views)
Study up on dataflow.
You're always going to be waiting in your inner while loops with this structure.
Look into Event Structures or using a Shift Register to track value changes.
Your polling while loops inside of another while loop will not work for your intended purpose.
Message 2 of 8
(5,846 Views)
Accepted by 416E64
Your code is way too constipated. Here's one simple solution.
Message 3 of 8
(5,840 Views)
 Smiley Tongue thx~
Message 4 of 8
(5,827 Views)
Wiping coffee off my monitor now....
Sometimes you just know when someone's Freudian Slip is showing.Smiley Surprised
"Should be" isn't "Is" -Jay
Message 5 of 8
(5,813 Views)
No slip. thats exactly what I meant.
(the stop will work after switching the boolean a few times, it's just a constipation issue. Impaired dataflow) 😄
Message 6 of 8
(5,806 Views)
in the new attached file where i added "read digital input",
how to use one single stop button to abort the whole program with two loops,
and how to set the default port as "port 1" but not "port 0"?
Message 7 of 8
(5,785 Views)
All you need is a single loop (and stop button). Just place the code from the lower loop inside the upper loop.
Your current code is not stable because the lower loop might miss an update (race conditions!). What determines the loop rate of the upper loop? Is there some hardware timing or does the loop need a small wait?
You could even monitor multiple lines by tapping into the boolean array and maintaining an array of numeric in the shift register. The rest of the code basically stays the same.
Message 8 of 8
(5,779 Views)
