can we Compare wav music file with its CSV File
Hello Everyone,
Im Playing a .wav music file and Generating its csv file, can we compare this csv file with the .wav music file in LabVIEW...??  to check whether the music is played properly or not.
Thanks in Advance
(2,398 Views)
I'd say yes, you can.
You can read the data from a wav. And you can read the data from a csv. And you can compare data for sure... So that ticks all tags.
(2,382 Views)
Hello Sir,
Thank you and I will try Once.
(2,363 Views)
Heck, you should be able to play the csv file if you had something that could read the file fast enough.  Speaking of which - you KNOW this file is going to be huge, right?  Maybe even between two and three times the size of the .wav file, depending on the content.  Every 16-bit sample has the potential to be 6 bytes (characters) -- five characters + delimiter.
Bill
CLD
(Mid-Level minion.)
(2,357 Views)
