can't install Datalogging and Supervisory Control Module 2014 with labview 2014 64 bits
hi NI community
I installed labview 2014 64 bits, then I tried to install Datalogging and Supervisory Control Module 2014
http://www.ni.com/download/labview-datalogging-and-supervisory-control-module-2014/4848/en/
but an error message display ''labview 2014 must be installed. Do I have to install labview 2014 32 bits, is there any other solution
further morem, trying to install real time 2014
http://www.ni.com/download/labview-real-time-module-2014/4832/en/
an error message display ''labview 2014 32 bits must be installed''. is there any version for lv 2014 64 bits
thanks
(5,643 Views)
Accepted by topic author Guefrachi
The compatibility matrix is here.
You need to install LabVIEW 32bit.
Do you have a specific need for 64bit LabVIEW?
(5,576 Views)
If RT is your goal, you don't have any need for 64-bit.  You generally only want to take a look at that if you're going to be doing something computationally intensive, like heavy image processing.  The modules you're going to want are all 32-bit support only.  You can install the 32-bit version on your 64-bit OS just fine.
As altenbach pointed you towards, there's a compatibility chart you can look at prior to installing/downloading tools.  You'll see a large portion of those are 32-bit only.
(5,526 Views)
thank you very much, this make things clear for me.
well, since I have 64 bits I am always looking for 64 bits sofware.
(5,403 Views)
