can i get a sample vi that converts a .wav audio file to bits?
(3,918 Views)
Hi learner14,
can you explain a bit more?
Mike
(3,916 Views)
Actually i want to convert an audio file into bits and then use these bits for modulation and then again retrieve the audio file. So if you have any related vi for conversion of audio file or .wav file into bits please send it
(3,902 Views)
Start with the Sound File Read on the Graphics & Sound>Sound>Files palette.
(3,880 Views)
This seems to be the third request this week having to do with modulation. I smell a school project.
(3,873 Views)
As a start go to to help in the toolbar. Then find select Find Examples. Search for sound and locate the "Sound File to Sound Output.vi" This is for sound output but you can delete all the stuff related to sound output. If you right click on the "Sound Read File.vi" functionYou can select the data type the type you want it to output, with the "Select Type" option. In your case I think it would be I16 or I32. You can then extract the data from the waveform wire, and create a bit stream
Message Edited by Coq Rouge on 03-28-2010 06:04 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,862 Views)
