How to trim graph at a given point?
Hello forum.
I have to trim some parts from a mixed signal graph using  a cursor. I need to be able to cut before and after the cursor at certain given points (selected manually). Can anyone please tell me what i should do? I can't find any function related to trimming.
Thanks in advance.
Serban
(4,006 Views)
Accepted by topic author arckadii
Hey Serban,
I found a piece of code that looks like it does what you are wanting to do. Basically, you move two cursors on the top graph to change the window of the bottom graph.
http://zone.ni.com/devzone/cda/epd/p/id/4308
From a programming standpoint, it takes the cursor position properties of the top graph and applies them as the min and max scale properties as on the bottom graph.
Logan H
(3,980 Views)
That resolved my problem. Thank you very much.
Serban
(3,976 Views)
You should not mark your thank you as the solution. To change the marked solution, click on 'Options' above the message body.
(3,970 Views)
Sorry. Thanks for letting me know.
Serban
(3,965 Views)
I gave you a Kudos there Dennis because i think you have hit on a valid point. In fairness to a lot of people on this forum its not clearly defined (i beleive) how to Kudos or what it is and especially how to mark a solution as solved. I have recently gone into various topics to have a look only to find that the problem has been solved but not marked (Or the person helping even getting a Kudos). I dont think people are being rude, i just think they genuinly dont know what to do.
"Everything should be made as simple as possible but no simpler"
(3,938 Views)
That's because no one bothers to read the help for the forums. Just like new users never seem to bother reading the LabVIEW help.
(3,928 Views)
