can draw more than 1 virtual line as ROI in an image display??
may i know is that possible to input more than 1 virtual line as ROI at the image display??
thanx for helping me...
(3,063 Views)
wuliao23,
You can draw multiple ROI's on your image if you hold the CTRL key down.  (Show the ROI tools.  Rt-click the image, select Visible Items...ROI Tools and make them visible.)  You can also show/hide specific tools on the ROI pallet, right click the pallet and select Visible Items...ROI Tool Button Visibility.
-cb
(3,060 Views)
yes...
thank you...
i have a new question..
now i will draw 2 virtual lines on a image-- virtual line "A" and virtual line "B"
may i know that is that possible to specified the ROI for virtual line "A" and virtual line "B" differently??
because i need to do the edge detection...
then i need to specified is this the edge detected by virtual line "A" or virtual line "B"..
is that possible to do so by drawing 2 virtual lines on a image??
(3,030 Views)
wuliao23,
Take a look at "Edge Detection Example.vi", I think it does a lot of the things you are trying to do.  You can use a property node linked to your image to iterate through the ROI's drawn on your image and find edges for each.
-cb
(3,010 Views)
