can I use an event structure within another event structure
Hi
Can use an event structure within another event structure?
Yasamin
(2,895 Views)
In general, that would be a very bad idea. Why would you want to? An event structure is always capturing events and not just when your outer event is active. This can very easily lead to your entire program locking up.
(2,892 Views)
And why would you want to do that...?? Would you mind elaborating the requirement here..??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,887 Views)
I attached my Vi from my old project (MY OLD VI). It is worked correctly.
But I decided that use event structure instead of case structure.
I attached my new VI as a picture and as a LabVIEW VI too (network_analyzer_8510_920527 Frequency Sweep.vi )
My graphs show by pressing "case 5: button (Bottom of page right hand).
Then I want to show each of graph in a large window( in a new VI) by clicking a key (for example "show 1").
Yasamin
(2,878 Views)
Accepted by yasmain62
I would save your waveforms in shift registers.  You can then use your main event structure to trigger on the Show 1... value change events and process the data however you need from there.
(2,834 Views)
