can I insert a column of array into mysql?
Sorry, I don't understand your syntax. You originally said you needed to update a column but your image shows multiple columns. The syntax that I linked to will write multiple values to a single column. A simple change would be to use an insert for each column.
Message 11 of 14
(1,937 Views)
Accepted by behzad1
See attached file.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 14
(1,936 Views)
Thank you.
it seems Yamaeda example data format, would make suitable input to  your suggestion insert multiple.
that picture was my first test for repeating insert and was not for multiple. please see my new picture. is any problem now?
Message 13 of 14
(1,925 Views)
Hi  behzad1
I checked your VI and it looks just fine to me. Lets see is Dennis_Knutson can give you his opinion too.
WenR
Message 14 of 14
(1,876 Views)
