calender
How to make a calendar in labview 6.1 using RING?.Applying conditions that we select a month suppose feb so it contains 28 days......& same for other months also.
Message 1 of 15
(4,491 Views)
Why you want to reinvent the wheel, you can reuse the .NET based control.
Date and Time
If it is a stringent requirement, I would suggest create a X-control.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 15
(4,471 Views)
offcourse ..but in labview 6.1 there is no such kind of function.
can i know how to make calender easily in Labview 6.1?
Message 3 of 15
(4,451 Views)
Hi priya,
that are two points in one question!
Do you want to have a calendar control in LV6.1?
Or do you want to have it the easy way?
Start by thinking what you need to represent that calendar control.
Then start to think of a state machine approach to handle all the user input to that control.
Does LV6.1 even have the timestamp control as newer LV versions have?
Can't you upgrade to a more recent version of LabVIEW? LV6.1 is outdated the same as WinXP nowadays…
Message 4 of 15
(4,444 Views)
i mean that a functionality that user inputs date in dd-mm-yy format from a calender created.
Message 5 of 15
(4,441 Views)
Hi priya,
can you set the display format of a numeric control to absolute time in LabVIEW6.1?
Message 6 of 15
(4,437 Views)
In english
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 7 of 15
(4,428 Views)
Hi Ranjeet,
I was using a "simple" numeric control, NO timestamp control!
Message 8 of 15
(4,416 Views)
As labview 2012 have the timepicker control... i want to create the same in labview 6.1 as it does not have that in built feature
kindly give me the  screenshot of solution as creating the whole calender is quite timeconsuming.
Message 9 of 15
(4,406 Views)
Hi priya,
what "timepicker" are you talking about? Never heard of…
Does LV6.1 support the "absolute time" formatting of numeric controls as shown above? That would be the easiest solution…
Message 10 of 15
(4,394 Views)
