calculating beat per minute
I use Labview 6.0. Icouldn't open this vi.Would you please save it in 6.0 ?
Message 11 of 20
(1,964 Views)
Sorry, I can't.
But here is an image of the vi...
Hope this helps !
Chilly Charly    (aka CC)
Message 12 of 20
(1,964 Views)
Dear Charly,
I've tried to do what you said to me. But I couldn't achieve. Would you please have a look at vi attached. I couldn't synchronnize loops. And I really don't know if I did the right thing for other parts of the vi or not .
I need your help.
Message 13 of 20
(1,964 Views)
Do not pass the "Actual sample period" between the loops. This blocks the second loop that will wait indefinitely for the first one to stop that's called "dependency".
Instead, create an "Actual sample period" indicator in the first loop, then create a local variable of this indicator, put it in the second loop and wire to the div nodes.
If you want to explore other solutions to the loop synchronization problem, you could have (latter !) a look to the "Queue" function.
Keep wiring !
CC
Message 14 of 20
(1,968 Views)
I've created a local variable for actual sampel period and put it in the second loop .
But second loop runs only one time and then first loop runs infinitely 😞
Also while second loop runs once,data comes as #0 to division node so I still can not calculate beat per minute.
I don't have much time left to finish this vi.
What should I do now?
I'm sending the modified vi and a better file record.
I'm waiting for your help.
Best Regards...
Burcu
Message 15 of 20
(1,957 Views)
Here is the file record.
Message 16 of 20
(1,958 Views)
OK, I found again your posts.
Message 17 of 20
(1,938 Views)
Hi Charlie,
Of course I kept my promise and wrote down your name 🙂
I know that to calculate the absolute
time the formula is
Sample period=1/sample rate
But I don't know how to implement this to .vi
Would you help me for the one last time,
promise I won't bother you anymore 🙂
Message 18 of 20
(1,906 Views)
In my previous post some characters are missing.I'm wroting again.
The absolute time is
trigger time+sample number*sample period
for my vi sample period is 1/sample rate
sample period=1/440=0,002272
Enclosed I wrote a vi for this formula.But I don't know how to implement this to my vi:(
I wonder that when I create an indicator for date/time string in my virtual instrument vii I can see acquisition time and each time value of 433 samples.However, why can't it save these time values as seen in the front panel.
I appreciate your patience to me 🙂
Regards
Message 19 of 20
(1,902 Views)
@Burcu wrote:
Of course I kept my promise...
Only part of it !
Anyway, the answer has been adressed to your most recent post...
CC
Message 20 of 20
(1,875 Views)
