How do you save a VI and later have a program load that vi?
I am writing a program that will save a VI with experimental information. From another VI (which is the engine performing data analysis) I want to be able to programatically load the VI that was saved with the experimental information.
I have labview 5.1 and am using a win98 OS.
(2,522 Views)
I think that what you're really wanting to save is the experimental data and the corresponding parameters. There are a number of ways to do this. One way that I often use is to format the information into a spreadsheet string and save it to an ASCII file. As long as the format of the spreadsheet string is known you can write a reader to recover the data in your analysis program. This approach has the advantage that the data can readily be imported into other software packages as well. Without knowing more about your particular experiment it is difficult to say whether this approach is suitable or another approach is more appropriate.
(2,513 Views)
See if you have the functions described in this link in LV5.1:
http://zone.ni.com/devzone/conceptd.nsf/webmain/04F9CCB32C67F24386256802007B
878F
"Mitral" <x@no.email> wrote in message news:172632@exchange.ni.com...
information. <br><br>I have labview 5.1 and am using a win98
OS.<br><br>Thanks
(2,511 Views)
