cRio ftp server closing connection
I have a cRIO with a datalogger Vi running on it. That Vi creates files where the data is stored.
I use FTP to get the files and worked fine withing our LAN. The problem arise when I want to get the files with the cRIO connected to internet with a GPRS modem.
I can download small files ( up to 60Kb ), but if I want to download a bigger file I get an error "Connection Closed by the Server". To see that error I used Filezilla Client FTP.
Anybody know what could be happening?
Using:
Hardware: Controller cRIO-9012,  Chasis cRIO-9101 and Module NI-9215
Software: Developer Suite 8.6.0
Thanks.
(3,691 Views)
A little more information....
I had make some test:
1- I installed an ftp server in a PC (CesarFTP) connected to internet by the GPRS modem. Then I could download files, much bigger than 60Kb, without problems.
2- I putted the cRIO in Safe Mode and I could download files, much bigger than 60Kb, without any problems too.
(3,663 Views)
Accepted by Juanjo339
Hi Juan,
To solve this issue it was necessary update an file and then sent it to customer.
Jailton - NI Brazil
(3,550 Views)
