09-02-2021 05:48 AM
I'm trying to develop a cRIO standalone application using the cRIO-9054: the target is to start the data logging procedure without the need to maintain the connection to a PC. Is there a way to control the C-Rio without any input from the LabView environment? How can the data-logging start with no LAN connection between the C-Rio and the PC?
09-02-2021 07:14 AM
You could use a digital input to trigger logging.
09-03-2021 07:25 PM
The cRIO can "see" whatever is connected to it. In particular, it can "see" the data that it is recording, and (possibly) can "see" a clock. So if your criterion to start data-logging is data-based (i.e. "start recording when the voltage exceeds 3V" or "start recording when the S/N ratio is > 2.3"), the cRIO can "control itself". You can also, say, connect a push-button to a DIO line and say "Start acquisition when I push this button".
09-10-2021 06:50 AM
You can trigger DAQ in multiple ways:
Luckily your 9054 RIO has PFI bus (the golden connector) which you can use (and connect it to FPGA too, but it is a little bit tricky) as a digital input. Having a button, you can come up with a simple circuitry which can be used for triggering DAQ.
