cRIO standalone application
I'm trying to develop a cRIO standalone application using the cRIO-9054: the target is to start the data logging procedure without the need to maintain the connection to a PC. Is there a way to control the C-Rio without any input from the LabView environment? How can the data-logging start with no LAN connection between the C-Rio and the PC?
(1,627 Views)
You could use a digital input to trigger logging.
(1,613 Views)
The cRIO can "see" whatever is connected to it.  In particular, it can "see" the data that it is recording, and (possibly) can "see" a clock.  So if your criterion to start data-logging is data-based (i.e. "start recording when the voltage exceeds 3V" or "start recording when the S/N ratio is > 2.3"), the cRIO can "control itself".  You can also, say, connect a push-button to a DIO line and say "Start acquisition when I push this button".
(1,564 Views)
You can trigger DAQ in multiple ways:
  • After startup
  • Time elapsed since last DAQ
  • Digital trigger signal is rising/falling (through DI or AI modules)
  • Your measured signal has a specific characteristics (start DAQ only if signal RMS > limit)
  • Network communication
Luckily your 9054 RIO has PFI bus (the golden connector) which you can use (and connect it to FPGA too, but it is a little bit tricky) as a digital input. Having a button, you can come up with a simple circuitry which can be used for triggering DAQ.
(1,536 Views)
